This is from an Africa twin site.....
The immediate and naive thought that immediately comes to mind is:
- Access the source end of the cable.
- Detach and clean-up the end.
- Solder the affected braided wire so to stop the wicking effect up into the conductor strands.
- Follow this up by an application of heat-resistant epoxy around the conductor sheath end and the wire itself. This prevents oil from getting between the sheath and conductor, bypassing the soldered braided fix and resume the wicking behaviour along the remaining length of the cable.
In theory, that should stop the wicking behaviour. However, will oil now drip when it hits this interface?
Alternative thought:
- Strip away about 1/4 to 1/2 inch of sheath not far from the source connector.
- Solder the conductor so all braided strands are bonded.
- Dip the entire 1/4 to 1/2 inch unsheathed area in heat-resistance (oil resistant) epoxy.
- Consider wrapping the section in electrical tape or similar protection.
This too, in theory (??) could plug the wicking of oil by way of the internal cable conductors.
