P500 Electrical issue
aauman88
aauman88
1,091
2,846
I have a 500 that we are rebuilding and can’t get it to run now. The third fuse down on right side has no power and the dash doesn’t light up. Can jump power to the fuse and dash lights up. The four relays also power on when power is jumped to the fuse. Turns over but no fire and don’t think the fuel pump comes on either.
Question is does the ecu power that fuse or does that fuse power the ecu? I have a PV3 and the diagnostic port under hood does not have any power at any time. I believe the ecu is bad but I could be on wrong path. New ecu won’t be here until next week so seeing what someone else thinks.
Thanks in advance
3EB3621E 3B25 4759 9EBE 264A7C8B9654 CF12545D 3B3B 468D B6CC F19F5303E81D DB53D52B 6228 407B B598 604317B0C763 892DFFDA 4E59 4982 9D5B AFE3C3DD932D 6A7B9C70 35A4 4489 A33B A800A16391A4
Reactions: Mudwing and TxDoc
HondaTech
Do you have the fuse box lid to narrow down which fuse your having issues with?
Also what year?
Reactions: TxDoc
aauman88
aauman88
1,091
2,846
2017 and the lid was missing when I bought it. I have one on order with the ecu 🤷🏻‍♂️
Reactions: TxDoc
HondaTech
Dang, we don't have a 500 at work to reference either.
There's only one row of fuses on a 500, right? Besides the spares?
None of the fuses are controlled by the ecm.
Maybe pull the box and look which color wire is coming from the fuse your having issues with.
Reactions: TxDoc
67,230
looking at 2015 info...
3rd fuse is the fuel pump relay.
It gets its power from the 40A main fuse.
40A main fuse is connected directly to the battery.
Both should be all the time hot.
Reactions: TxDoc
67,230
@HondaTech, where is the 40A main fuse on a 500?
Probably close to the battery in a gray small fusebox. If not inside the battery box.
Reactions: TxDoc
aauman88
aauman88
1,091
2,846
Yeah it’s in-line about 6” from battery. But if it was bad would it even be trying to crank ?
Reactions: TxDoc and Hondasxs
aauman88
aauman88
1,091
2,846
I ruled it out and didn’t even check it 🤦🏻‍♂️ Let me check it first thing in am.
aauman88
aauman88
1,091
2,846
Alright went and checked. The 40a is good. The fuse in question is the 3rd down on right side, 30a. All other fuses are good and have power, that fuse is good but no power to it.
4A9B8E5B 1602 4429 B883 BA4B02976C9A 9011FEB0 F18B 4E81 9F8B 5DF180CB37EB
Reactions: TxDoc and Isaiah
aauman88
aauman88
1,091
2,846
If I jump power to it the dash lights up and here relays energize but still won’t fire. It’s like a safety has it out.
Reactions: Isaiah and TxDoc
67,230
Just got in the bed.
But i will send you the wire diagram tomorrow.
Again this is 2015.
You can see the fuel pump relay fuse gets its power from the 40a.
If the 40a has power the fan and fuel pump should too. 839ea448a1a4795f3aa53548ffc44187D3bfd4a0d1ba031895873cf9faae239c
HondaTech
View attachment 249734 View attachment 249735
Which fuse in this picture is no powered?
The wiring diagram is upside down i believe, because the 30 amp fuse off to the bottom should be the main. The 3 holes on the left are spares holes.
If you follow the wiring diagram fuse count, the 3rd fuse from the top is actually the light fuse. Anybody with a P500 care to grab thr fuse box lid and look.
aauman88
aauman88
1,091
2,846
Third one down from top on right. 30a green fuse
aauman88
aauman88
1,091
2,846
The layout on that diagram is different I guess from mine being 2017. The Inj/Ign fuse is fed with black wire with white stripe from the PCM. That’s the fuse I don’t have power on. So it’s looking like it is the PCM bad unless there is some trick when hooking up the PCM?? My buddy said unhook it and battery and hook PCM up first then followed by battery. Will try it later but don’t see it helping
