I am a complete novice with regards to installing anything electrical,, but I want my accessories to work 1) safely & 2) Flawlessly as long as I own the P1K5 Deluxe. I have relatively few accessories; currently all are LED with the exception of the winch and no huge 40-50” light bars or fancy stereo systems. This is a Hunting and Farm vehicle first and last. For some reason, most of not all of the LED equipment already has relays which wold amount to four or more items worth replays further compromising space under the hood. My preference would be for a single relay in combination with a separate key on fuse box for power distribution. I will replace the supplied rocker switches(6) with 5 Poles OTRATTW (dual switch lights ). In essence, I need some help in hooking all this up the safest and most efficient way possible. I understand I need to daisy chain the six rocker switches (+ and - separately of course. I also understand the switch background lights should be paired with the dash lights (?) but don’t have a clue about searching for that. Further to this dilemma is how to spec.and install the relay, locate the “Key On” hot wire to fire up the replay, etc.
If there are some excellent links here or YouTube please advise as I don’t want to waste anyone’s time.
