G
I’ve just installed a dual battery set up. The previous owner installed a heater and windshield wiper that I would like to now run off of the auxiliary battery. It appears that the power for the accessories currently run from a fuse box into the main battery via a single positive cable with an in-line fuse and a ground wire running directly to the main battery. Is switching these accessories to the auxiliary battery as simple as just moving that positive and negative wire over to the auxiliary battery? I see there is a 3rd spliced wire coming out of that fuse box that is hooked up so these accessories only with with a key on. Wiring newbie here. Thanks.
