P1000 Engine cooling and Cab heat fix (test & info)
208,730
Keep in mind this is real world test and wind maybe blowing harder one day may have less sun and more shade. Numbers are what they are I don't care how they compare to other test.
See pic for new placement of fan.
Test 1
Outside temp 90deg
Under seat- No fan- 153deg
Under seat - Fan on- 139deg
Side of seat hot spot- Fan on 129deg
Side of seat hot spot- fan on- 129deg
Driving around no load- Fan on- under seat temp- no change in deg
At this point I checked Radiator temp 178deg (This is n't changing but the big test under load)
Test 2
Outside temp 108deg
Under seat- Before- 139deg
Under seat - After- 165deg
Side of seat hot spot- fan on- 135deg
At this point I checked Radiator temp 199deg
To give an idea how hot it is
Sand 143deg
SXS roof 128deg
SXS dash 125deg-135deg depending on spot you check.
My pants was 111deg
Its hot
My opinion I think the new placement helped the cooling It was 9deg hotter and at the end of the trip the Radiator was 4deg cooler. It still was at 3 bars.
Going to leave it and see how it does this week Friday temp will be 99deg so will be a better comparison. But it has done it every afternoon for 2 weeks so even tomorrow at 94deg should tell me if it helps.
Bonus I have the Alienshade mesh roof with my Hard top on I knew it was helping cool the cab but no idea how much test showed Roof 125deg mesh roof 109deg. (See Pic)
I installed my fan on the other side, blowing on the header pipes?????
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
Thats how mine was originally see first post I swapped to see if cooling the Transmission would yield a better results as far as cooling the motor.
208,730
And? My drivers side doesn't seem too hot, the passengers side very hot.
chipolariverman
chipolariverman
67
Malone, FL
Bradley-Thornton could you put a fan on both sides of the motor to blow on the tranny and the header?
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
I may have miss understood the question. Yes you can If you go back to my first post you will see at first I had it on the header and swapped it.
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
Ok, So the Inkbird Dual Stage DV 12V Digital Temperature Controller relay is only good for 10amps and the fan is 7amp so I will have to add another relay to that one so I can run 2 fans
T
tzink
14
10
indiana
Hello I am trying to do the bilge fan also. But this is in the way. It’s a 2020 and I don’t see it on any of the other post.
391D6115 D248 491B 88A7 B33EED62B3E4
Reactions: TimG
67,231
I still only show its for Kalafornia models.
Did you buy it in California?
Reactions: TimG
67,231
No in Illinois, possibility of removing it?
I wouldn't remove it. I say that just because i really don't know what its all tied too.
Did you know you were buying a California model?
Confirm it by checking the following.
Warning plate just under the driver seat.
If max weight is 1248 its a CA unit.
If it is 1649 its a 49 states unit.
Load rating sticker in the bed.
600lb is a CA unit
1000lb is a 49 state unit.
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
they let me start using my 98 Jeep and it has AC so test ended. I'm going to add another fan and have 1 blowing air away from the header and 1 blowing air over the transmission side. From My test I think it will help. Also I think it would help to add open and close vents at my legs so I could pull cool air out of the cab.
Reactions: chipolariverman
chipolariverman
chipolariverman
67
Malone, FL
That's what I was thinking of adding was some vents behind your legs to pull some cooler air into the engine bay. Even thought about putting a 7"fan there.
Reactions: Bradley-Thornton
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
I did a ton of looking and this looks to be the only thing I could find that I could open and close that would fit nicely.
