P1000 Engine randomly going dead now will not start
Mike j
11
Mississippi
I changed the head gasket on my 2017 1005. After a year with the trying to get some one to work on it with out taking to the Honda shop. Was told nothing was wrong with the gasket. But in the end it was. So back to my issue at hand. After I put the machine back together I ran it around the house over about 3 days. Not over 4 miles or so at a time. It ran great not running hot or anything then it started to randomly going dead it could be part or moving when it happened. Now it will not start. I believe it is the injector wires but not sure. Looking for some in slight. The engine light has one long and 3 quick flashes.
Thanks.
Reactions: TxDoc
Mopower58
Mopower58
CST is the Best!
79,418
706,149
Crystal Springs,Ms.
Welcome from Mississippi. I think a code 13 in an injector harness fault. Someone that knows a lot more than me will come along.
#NTC
Reactions: TxDoc
115,286
Thanks.
Yes u need an Injector harness.
Welcome from Michigan!
Got any pics if the rig? POIDH
First owner? Miles? Why did you have to change the head gasket?
Your leaving us hanging here like Epstine! 😂
0860silverado
954
1,834
louisiana
Code 13 is number two (rear) injector not firing. It's a relatively common issue and an easy fix with the kit that is sold on this forum.
Reactions: Remington and TxDoc
Mike j
11
Mississippi
Update installed the new injector harness. Good to go. On that part. But it about time for clutch replacement has any one use an after market clutch.
DRZRon1
DRZRon1
1,198
3,859
PA
does anyone make an aftermarket clutch?
I need to be educated…..
Reactions: TxDoc
