P700 Engine Stall on trail
LandPioneer
LandPioneer
929
2,417
Lebanon TN
I have an issue of my engine stalling on the trail. I've tried to take notice when it happens and what I was doing when it stalls. Here's what I think I know: The engine stalls when I give it gas and then let off. Usually when I'm about to flip so I let off pretty quick. I read where people mention not letting off the gas abruptly resolved it. However, in these situations that isn't possible. Anyone else experiencing this? Able to find a resolution? It really does suck having to restart my machine while sitting in a precarious situation. I have to hold the brake with my left foot and get it started back up.
scott
scott
1,212
1,354
lyman, South Carolina
Just letting off the gas really quick should not stall it. Letting off quick and then pushing gas really quick again. Or doing it a few times in a row has caused them too stall. Oil overfill helps with smoother gear changing and letting the tranny get oil on steep grades. So I'd go ahead and add some oil. I know the 14 doesn't have the tip over sensor but not sure on the 15-16-17. I don't recall mine ever stalling since I put the UNI air filter and exhaust tip on. Even when I let off and push fast again. Other than what I've said I don't know what it is in your situation.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
It only happens when I'm in a tough situation so I'm not 100% sure. I'm more worried about turning over Lol. I do think it is happening when I let off quick and then gas it. And usually I am on a steep grade. It starts right back up but it is really annoying.
I will try the oil overfill and see if that helps. I planned to change over to synthetic oil this week anyway.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
If you do and more oil keep a eye on your air cleaner for oil and leaks sometimes to much oil can cause your seals to leak.
Reactions: LandPioneer
SuperYeti
SuperYeti
220
375
Vancouver, BC
I've had the same issues, and ruled it out to how the automatic transmission works. When you're on the gas, and then suddenly let off, the torque converter just doesn't seems to always release quick enough, causing the engine to bog and stall. You can do similar if you hold your foot on the brake, and gas it, it revs to a certain point, then dies. Pretty sure it's just inherent to the design. I *think* since I switched to synthetic it's much better, or I may just have learned better throttle control sub consciously to prevent it from happening more, *shrug*.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Well I did my first oil change last night. I'm running Amsoil 10w40. Hopefully this will resolve my issues. I'm going riding this weekend so I'm sure I'll find out!
QuadMan747
QuadMan747
344
566
Connecticut
www.cccmx.com
  2. Other Brand
Mine stalls when I "blip" the throttle as well, I'll worry about when/if it doesn't start back up. :)
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Usually it isn't a big deal but we've been tackling some harder trails lately. When you have 2 wheels off the ground and your d@mn machine dies it is NOT a fun feeling Lol.
Reactions: QuadMan747
SuperYeti
SuperYeti
220
375
Vancouver, BC
That just adds to the excitement! You'll quickly learn how to manipulate the better, and not be so jerky on the rough stuff anyways heh.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Well after a complete ride with some pretty rough terrain I am here to report I had zero stalls. I'm not 100% sure if it was all the oil change or me more aware of how the machine performs. I don't think i drove any different though. I'll report back if I have any stalls over the next few rides...
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Glad to hear it man
