P500 Extended fenders Instead of fender exstension
Chooglin
I added 1.00 spacers in the rear , so I figured I should extend my fenders (2.00")
One side is complete , one side to go !!
I used my stock skid plates for the filler piece !
20160821 145024 20160821 145039 20160821 153801 20160821 153823
solrus
solrus
1,629
2,511
Montana
Chooglin
What did you use to bend stock skid plate? Heat gun? and did u sue clips or screws to hold fenders?
Could you please show your tools and everything u used for this project.
Thx!
I used a jigsaw to cut the plastic , a propane torch to heat it and Honda push pins to secure it !!
I will post some more detailed pictures when I get home from work tonight !
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I look forward to more pictures. I'm 99% sure going this way for the rear. It looks like if I make four offset brackets to mount to the rack, can avoid drilling those holes in the fenders.
Reactions: Chooglin
solrus
solrus
1,629
2,511
Montana
Post your pics of diy also
Sent from my XT1585 using Tapatalk
Chooglin
I ordered new hood and fenders (yellow) so I will be making new brackets for the fenders so I don't have to drill the new fenders !
Chooglin
I am not real good with tutorials , so I will do my best.
1) cut a piece of cardboard 39"x 7" to start
2)line up the cardboard with the ledge on the fender and bend one end of the cardboard around the fender ( do not try to follow the ledge when doing this). Now make a mark on the end ,where the angle would extend out to the end of the fender and mark the center of the bend.
20160824 171040
3) now draw a line connecting the two marks you just made
20160824 171132
4) do the same thing on the other end
5)after you get the two angles drawn , measure a width of 3 1/2" along the lines.
20160824 171408
6) now cut the template with a utility knife
20160824 171431
7) cut the plastic using the template.
8)heat the plastic and make the bends using the fender as a guide !
Do not get the torch to close , you want to heat it , not burn it !
9)parts should look like this !
You will have a left and a right (mirror image of each other)
20160824 171538
10) transfer holes from fender and center piece to the filler piece and drill !
11) 4 of the holes will need to be heated and bent on a angle (the four holes closest to the seat)
20160824 171553
12) You will need 10 adittional push pins to assemble
13)either add 4 new bracket to the wrack , or drill your fenders and use spacers for the 4 bolts
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Thx for the additional pics and input.
So, it looks like I can get both out of a 12" x 48" piece of HDPE. Is it 1/4" or 3/8" thick?
Reactions: Chooglin
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
OK measured my bottom skid plate and got 1/4", and the part it will bolt to is 1/8". Ordering the 1/4" along with pieces for front flares. :0
