P500 Factory rim sizes
Moose308
386
289
What width are the oem rims? Thanks
bigc
bigc
432
127
fronts are 6in rears are 7.5in
Reactions: Moose308
273,461
Don't forget the offset, the fronts are 4+2 and rear 5+2, most aftermarket rims are 7 wide with 4+3 offset which will make you 2 in wider minimum start adding 11 or 12" tires easy to get +5" wider than stock.
STI rims make the 5+2 offsets with the Honda 4 x 110 mm bolt pattern on multiple styles.
Reactions: Mudder and Moose308
