fan not working
jae12
6
i just bought my sxs2 today i have 1.7 hours on it and the fan has all ready quit working does any one have any suggestions on what to check? i have all ready checked the fuse and it was good
bigc
bigc
432
127
i doubt there is anything wrong with it -it is thermocally controlled and only kicks on when the temperature exceeds the temp sensor limit
jae12
6
well it started to over the light came on took the hood off and the fan was not spinning
bigc
bigc
432
127
if it overheated then yes there is something wrong check and make sure the fan is plugged in good or have dealer fix it under warranty if the dealer is far away you could put power and a ground to the fan plug that would test the fan itself if its good then it could be the temp sensor
