Any increase in power is an increase on stress, wear, tear, etc. A Turbo is going cause early wear and in some extreme cases, breakage.
That said, there have been thousands of turbo kits installed out there and the only breakage I have heard of is...
- Early tunes were wrong (too much timing I believe) and Jackson replaced a few (VERY few) engines to make it right. Since then, everything quieted down on that front.
- Racers running them hard have broke a few but racers break everything they run so that doesn't count.
- A couple guys that have done their own tuning and/or increased boost so that doesn't count either.
- And even at least 1 NON turbo machines that has broken stock pistons.
Other than that, they seem to stay together for your average user. If you intend to run the dunes a lot, I would suggest forged pistons BUT I am not aware of any that are the same compression ratio as stock
Stock 10:1
CP sells 9.5, 10.5 and 11.5:1.
Wiseco sells 9.0 and 10.5:1
So you either use 9 or 9.5:1 and now you are down on power so you have to figure out how to raise the boost. BUT the stock MAP sensor only reads 8psi (thus the reason everyone is stopping at 8).
Or you go to 10.5:1 and now you are running race fuel.
In any case, if you put a different CR forged piston in, then you have to change the tune. At this time, forged pistons are a can of worms until you can find 10:1 forged pistons.
Note: CP *might* sell custom pistons so you might somehow be able to get 10:1 forged so you don't have to mess with all the tuning and MAP sensor s*** (unless you want to of course).
