P1000 Fixing Flats...
Plongson
Plongson
271
1,027
Southern Utah
How are you guys fixing your flats?? Plugs or breaking down the tire and patching the inside? I'd Like to patch but I'm not sure how get it off the bead without too much "Brute force and Ignorance"...
Any suggestions?
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Plugs on the trail. Then if the hole is really bad I found a local place that will vulcanize the tire. Basically the go in and put new rubber in where the hole was. The procedure does cause come cosmetic disfiguring but it make that spot stronger. You can see in the two pictures below where I had three holes vulcanized below where they needed to grind off some of the side lug.
IMG 4673 IMG 4672
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
Are you looking for a step by step guide or redneck tips?
Redneck tip 1 High Lifter jack under the bumper makes a good bead breaker
I have had no flats since I put tire sealer in.
Plongson
Plongson
271
1,027
Southern Utah
Ya, Redneck tips are best...Ya can always fix flats with $10 bills but that's not my style...LOL
Breaking the bead is the PITA part, I was thinking about using the front blade of the bucket on the skiploader but one wrong move and you've dicked up a $200 wheel. Harbor Freight has a wheel machine pretty cheap, I might make a run and take a look.
Thanks...
View attachment 57756 View attachment 57757
I may need to send one home with you
13,378
65,295
You weren’t able to find anyone local?
Any over the road recap shop should be able to revulcanize the side wall of these things.
They wanted more than I could buy a new tire for!
320,091
Plugs have always worked good for us even in sidewall.
If you do break it down for patch or tire pops off bead, red neck fix 2( lol @GPR1500SC statement) one can use ratchet strap around tire and beer on bead to help seat for air. Or by slightly more aggressive means and use flammable material inside tire and throw match at a relatively safe distance.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
#3 on flammable bead seating 35% stuff works the best cheap unrated stuff and John Deer 85% is to unpredictable. :D
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
It cost me $30 a tire, this place is actually a big truck tire shop. It is not your normal type tire shop...
Reactions: JTW
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Any suggestions?
Piug it works just fine done it for years.
Reactions: Rincon
N
NorthStar
6
9
North
Thanks...
The only experience I have changing tires so far is on my Honda CRF50. Guys at the shop say they are the worst tires to change due to the small size and stiffness. I used to call a buddy to attack it with 4 tire irons. Since I bought that mini-wheel changer from HF it's taken a lot of the hassle out of it. I'm sure they make one for larger wheels.
Reactions: CumminsPusher
hoghead76
hoghead76
1,157
6,155
oklahoma
Thanks...
Don't waste your money, key word cheap
NTCPrezJB
NTCPrezJB
President of #NTC
100,760
900,304
Canton, OH
Plug or Plugs along with some superglue.
I don't know why, but just plugs often have very slow leaks for me. The addition of super glue to my plug repairs have stopped that entirely. I air the tire back to desired pressure trim the excess plug then slop super glue on the plug and quarter size area around it and then cover my super glue slop with baking soda which instantly sets the super glue.
320,091
I can see where that would help a lot. We try to use the rubber cement and douse the plugs with it. They go in easily and seal up good. I’ll give 5 min before air
jge3
16
kentucky
if a plug doesnt do it we break one bead and tube it to get home on. Beadbuster works great but alittle on the expensive side. Once home we have a tire shope that has large plugs with a patch on it they install from the inside of the tire. Think the plugs are actually intended for tractor and backhoe tires
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Heres a pic of a patch/plug beside the bead from a pinch flat. Held up good.
20180703 223951
20180703 224005
