Yoy may have to make a couple swipes with it, but it should work I'd think.Hi All,
Looking to see if anyone has any experience using a Honda for food plot preparation using a chisel plow like this. It's marketed to be used by ATV's so I don't believe power will be an issue, but just looking for any feedback before I make the purchase.
Do you not have a tractor?Hi All,
I see... I've never used anything but a tractor for plots.. I just don't see it working all that well.. I think it's going to be too light a plow and no lift could be a problem (would be for me). As was said.. it might work in loose sandy soil.. but I just think it's going to be a waste trying to plow.. if it were me I'd find a cheap old tractor and decent plow or Roto tiller to break things up good. Then you could use your Honda and a disk if you wanted.No tractor at our disposal all of the time. We're going to be working some land owned by a friend who's main occupation is farming, but we're looking to do this without having to take his time to do it. When we need to plant is when his equipment will be busy. It's sort of the deal for him letting us use the land.
Hi All,
A disk needs to be heavy.. VERY heavy. Again.. I think you're pissing in the wind with that.We're getting some similar feedback from the land owner. He thinks that we'll at least need a disc implement to break the ground up well enough to be worth the effort. So we're now throwing the idea around with one of these:
It's a bit more to buy, but I suppose may be worth it. Any opinions in that direction? Thank you for the comments by the way - obviously we're a bunch of amateurs trying 1940's farm techniques...
Yeah, don't blame you there.....especially if you've got other options.I have seen the Kolpin stuff, but we're not looking to get quite that deep into the equipment side of things (and we have guys available to provide seed spreading labor and stuff haha). The way we're seeing it, if we do need something that sophisticated we might as well either go to Tates Rents, or have the landowner bring his real equipment out and get the job done.
That second pic is a devise used after a plow has turned the soil over. It is meant to bust up the clumps it won't cut through virgin soil. I had similar Ideas when I did my plots of throw and grow max. I ended up paying the neighbors to use their rear tiller on kabota tractor.I know how frustrating it can be to just do food plots but don't give up.Some times I use my cub walk behind tillerWe're getting some similar feedback from the land owner. He thinks that we'll at least need a disc implement to break the ground up well enough to be worth the effort. So we're now throwing the idea around with one of these:
It's called a disk.. and yes you're correct, sorta. Depending on what you're planting, you can disk the seed in without plowing. Plowing just makes it better. Clover works well this way. But again... the disk has to be heavy to cut the ground.That second pic is a devise used after a plow has turned the soil over. It is meant to bust up the clumps it won't cut through virgin soil. I had similar Ideas when I did my plots of throw and grow max. I ended up paying the neighbors to use their rear tiller on kabota tractor.I know how frustrating it can be to just do food plots but don't give up.Some times I use my cub walk behind tiller
I agree 100%.It's called a disk.. and yes you're correct, sorta. Depending on what you're planting, you can disk the seed in without plowing. Plowing just makes it better. Clover works well this way. But again... the disk has to be heavy to cut the ground.
These are a plot of turnips and greens and the start of a clover plot first put in just with an old drag disk.. it probably weighs 1500-2000lbs.
