P1000 Four point harness
What are you guys doing with the stock belts?
Are you also disabling the speed limiter on the drivers belt?
What about harnesses for the seats in the back?
I pulled the driver and passenger stock belts out.. disabled the safety (there’s now a plug for it) I haven’t done rear harnesses yet.
Neohio
Neohio
Beast of the East
21,513
90,914
Painesville Ohio
Stock driver and passenger belt removed from mine completely. Using BCF bar and 5 point camlock harnesses.
17+ can have limiter disabled easily with the bypass sold in our forum store.
I haven't done anything with rear seats. I don't ever use them.
Reactions: JTW
Vikes79
Vikes79
SKOL!
11,874
114,619
South Dakota
  2. Talon X4 LV
I went ahead and ordered harnesses for front and rear seats.
I think it will help with the complaints I get from my kids about the metal seat belt brackets at their rears.
Thanks for the responses.
Reactions: Tramguage1 and JTW
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Is anyone mounting them to the angled headrest tube? Figured i could wrap around that and use one of the PRP straps to keep them togather. would like to get harness's before august but wont be able to get the bar yet too
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Mine were before i got the harness bar. Pics in my build
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
did you have any issues with it like that. Ill eventually get the harness bar as well
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
No problems at all.
20170627 183920
20170625 201625
A few of us are using factory take off X3 XRS retractable harnesses. I have mine welded to the ROPS but others are using Moses harness bar. I picked mine up for $225 for the pair shipped of eBay about a year ago.
85883587 F425 4865 A1E1 98F8430F310A
F72BFB30 E65E 41B3 A234 BB0881820B99
Kilo427
Kilo427
1,543
6,440
I started using the retractable like ohana and jtw. So far I do like them alot, I did get to test them out several times at tackett creek and they worked well.
Reactions: ohanacreek and JTW
WI-DitchBanger
WI-DitchBanger
6
I built my cage so no help there. Your more than likely going to need a harness bar unless you find a way to mount them behind the seat. Ideally you want them mounted a little under your shoulder height. If you mount them real low, when you go forward they want to pull down on your shoulders. If you mount them too high, you can slide up the seat.
Thanks for the reply brother! Ended up purchasing a harness bar from @Moses because it seemed like the most practical/safe way to go about it. Now I'm just waiting patiently for it to get delivered...:D
Reactions: Moses
