Got the shocks installed on Friday and they are great! The most noticeable difference is how they handle the big hits. I was not able to bottom them out, and I tried. So nice to not have to worry about whether or not you will be able to handle a bump while driving down the trail! A couple of other things of note-
While the fox shox are the exact same length as the stockers, they do provide a slight amount of lift. I took a stock measurement and then a measurement with new shocks installed, then another measurement after riding with them for a couple days. With the way they are set from the factory they give you just under an inch in the rear and slightly less in the front. However the shocks are fully adjustable so if you wanted to you could keep the stock ride height or lift the pioneer an inch or more.
The front shocks go on really easy, for the rears I had to remove the sway bar and its still kind of tough to get them in but once in place they look and fit great
This probably goes without saying but the fit and finish of the shocks is really top notch. These things are pretty!
Well that's my impression of the fox suspension kit. If anyone is considering buying these and has any questions ill be glad to help you if I can
