P1000 Frame Openings- Rust, Mud and PIA to clean
outlawhondarider
outlawhondarider
2017 PK3
10
16
Dallas Texas
Anyone have an idea how to minimize the mud entering the frame in the front control arm area ? The front skid plate is welded to the frame rails, which doubles as the lower control mounting area and has several areas for mud and everything else to enter. It is impossible to clean and the wet mud will eventually rust the rails. Cant plug it as there are too many openings, but i was thinking about filling area with expanding foam. Anyone have thoughts on this ?
Mudder
Mudder
NTC Ambassador of Walls
11,657
88,026
No foam, holds moisture. Several threads on search. Using this aircraft spec. product that crawls up interior tubing walls. Using inexpensive air compressor parts sprayer (siphon) to spray it it. Just an option.
Multi - Tube frame rust protection
