P500 Frame / Roll Cage Adjustment on my P500
KyGal83
KyGal83
9,496
92,697
Kentucky
Note: Rambling write up- I will make adjustments when I sit down at the computer..
I purchased my P500 in March of 2021. I bought it used from an individual on Facebook Marketplace. I picked it up in Greenville, Tn. It had 73 miles and 13.6 hours on it.
Not long after I brought it home, I noticed it appeared to be leaning toward the passenger side. You can see it by looking at the roof line.
IMG 0928
IMG 5713
I tried to diagnose it myself, it was suggested as maybe shocks. Those seemed fine. I put a level on the floor of it, front bumper, and rear rack…. All perfectly level.
A couple of things were also off, that I thought might be the problem. Roof fit the frame different, Windshield did not quite line up with the roof, so we tried to adjust both of those, with no luck. They would not line up, and it still appeared tilted. So I finally chalked it up, to just an optical illusion.. but still felt like something was wrong.
Fast forward a little over a year, this winter Futzin and I took it to his basement shop; to add some upgrades, winch, Mudbusters, and a couple other things. One of the items required a rops clamp. It fit perfectly on one side, but noticed the drivers side ROP was shaped differently and the clamp would not fit.
So I compared my buggy and Futz’ Critter, I realized my roof roll cage had been incorrectly mounted on the frame at the dealership.
So these 2 pieces should assemble with the tubes from the frame and roll cage seated in alignment. A tab from the top roll cage and a tab coming up from the frame on each side of the tubes. Then a bolt thru each tab locking the frame and upper roll bar together. As in the 3rd picture here.
IMG 0931IMG 0932IMG 0933
Mine however, was bolted in this way… (Bolts are loose because I did not think to take pictures before we started loosing them.)
IMG 0905
IMG 0912IMG 0906
Basically the bottom bolt was just in the frame hole and not attached to the roll cage bar. The top bolt was only thru the tab of the frame and the bottom hole of the roll cage. Essentially this means it was being held together with one bolt. I am very thankful, I did not roll or turn over my P5 while this was incorrect. It would have done some damage as the misalignment created a very weak spot in my cage.
Here is how it looked after we corrected it:
IMG 0915
It is correctly seated as it should be!
I adjusted my windshield and roof, so everything now aligns exactly as they were intended to be. The change is drastic. You can see in these photos how much the windshield and roof had to be adjusted.
IMG 0918
IMG 0919
IMG 0917
Now my buggy sits level exactly how it should have been. I will admit I should have trusted my gut, and dug further into the issue to correct it sooner. But would’ve, could’ve, should’ve…
I am EXTREMELY happy to have it corrected and to get back out there own the trails.
IMG 0916
Fatsquatch
Fatsquatch
Approved Member
120,623
1,006,935
Hidden
View attachment 388430View attachment 388431
A couple of things were also off, that I thought might be the problem. Windshield did not quite line up with the roof, so we tried to adjust both of those, with no luck. They would not line up, and it still appeared tilted. So I finally chalked it up, to just an optical illusion.. but still felt like something was wrong.
Fast forward 2 years, this winter Futzin and I took it to his basement shop… to add some upgrades winch, mudbusters, and a couple other things. One of the items required a rops clamp. It fit perfectly on one side, but noticed the drivers side ROP was shaped differently and the clamp would not fit.
View attachment 388452View attachment 388453View attachment 388454
View attachment 388455View attachment 388457
Basically the bottom bolt was just in the frame hole and not attached to the roll cage bar. The top bolt was only thru the tab of the frame and the bottom hole of the roll cage. Essentially this means it was being held together with one bottle. I am very thankful, I did not roll or turn over my P5 while this was incorrect. It would have done some damage as the misalignment created a very weak spot in my cage.
I adjusted my windshield and roof, so everything now aligns exactly as they were intended to be. The change is drastic. You can see in these photos how much the windshield and roof had ti be adjusted.
I have very happy to have it corrected and to get back out there own the trails.
Wow that is horrible! I’m glad you figured it out and got it addressed.
Mopower58
Mopower58
Unburdened by what has been!
86,745
747,949
Crystal Springs,Ms.
Like you said, it's good you found it before it was needed. Good job to you and @futzin.
KyGal83
KyGal83
9,496
92,697
Kentucky
I bought mine from the dealer in Greeneville. I guess I'll need to get you to look at mine during the Takeover.
I am no expert.. But I would take a good look at it. It irritates me to think that: A: They assemble these Pioneers frequently, so they knew better B: When the roof did not line up, that is a red flag. C: YET again when the windshield did not line up, nothing. They did all of that and still did not realize anything was wrong. Yes, it took me a while also... but I am an accountant, not a mechanic!
It definitely was not the previous owner, If you would have ask that guy for a screwdriver and bolt ... He would have gotten you a glass of vodka & orange juice, and ran away!
It is just ridiculous. That could have gotten someone seriously hurt or worse. I am relieved it is corrected, The more I think about it the madder I get though.
ODAMO
ODAMO
1,380
3,640
The USA needs to bring back apprenticeship programs and ethics in business classes before its too late.
211,181
And indentured servants instead of open borders!
Reactions: CID
Jerryg
Jerryg
12,219
96,597
NEPA
In the high school here, there is a carpentry course and an automotive repair course.
The carpentry course actually builds a house and the auto shop has 6 lifts and a former Ford employee doing the training. And anyone can have their car repaired for free if they want to wait in line.
It's the inner city communist recruit camps that are ruining young adults.
Reactions: CID and Smitty335
Jerryg
Jerryg
12,219
96,597
NEPA
Honda is not the Honda they used to be.
The quality of my JAY, kills Honda's sloppy construction.
And my muffler isn't crooked either........
