Front A arm mounts
dnlljeremy
I bent both mounts that the front, top, A arm goes in on my Pioneer 700-4. Has this happen to anyone else? What can I do? Do they sell just the front part of the frame? In need of help, thanks!
66,449
Hi,
Welcome to the club.
Do you have a lift kit installed?
66,449
Oh.. you said a-arm. Not shock mount.
How did you bend these?
Still, a local welder would be your best bet. Then find out what you did to bend these and try not to do it again.
dnlljeremy
No lift kit, everything stock and yes A-arm mount that the front, top A-arm sits in.
271,180
Welcome @dnlljeremy Sorry to hear you tweaked your mounting tabs. Alternatively a body shop with a frame straightener may be able to pull everything back square.
Reactions: dnlljeremy
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
@dnlljeremy Sorry to hear about your 700-4!! What happened that caused it? this is the 1st i have heard of this problem. Can you post pictures? Welcome to the Club!
bagotaco
bagotaco
121
77
Got the same problem. It was like that when I bought it. Guy said his daughter hit a tree. Yes a body shop will fix that with no problem. I'll get a pic tonight. Since I can't figure out how to put it on here from my photo album on my phone
bagotaco
bagotaco
121
77
Here's the A arm and bent frame.
F
fatchev99
Fl
Hello, did you ever get this issue resolved? I have a similar issue.
motorman18
439
277
Laurel, MS
Yeah a lot of p700 broke the tabs out of the frame mine did climbing out of a rut I had to bend them back and weld them up good with a brace on backside from factory the one tab is only tack welded on one side it’s not welded front and back kinda crappy design on Honda part
Reactions: Mudwing
