On a 2019 700 2 seater what is the diameter of the small bar on top of the front bumper.
T T-bird New Member Apr 21, 2019 3 4 3 Poplar Grove, Arkansas Ownership 700-2 Nov 14, 2019 #1 On a 2019 700 2 seater what is the diameter of the small bar on top of the front bumper. Reactions: Russ989
Russ989 Land of the free because of the Brave! 🇺🇸 Lifetime Member Supporting Member Club Contributor Dec 18, 2017 22,639 147,230 113 Missouri Ownership 1000-5 Nov 14, 2019 #2 T-bird said: On a 2019 700 2 seater what is the diameter of the small bar on top of the front bumper. Click to expand... Not sure off the top of my head. Why do you need to know?
Russ989 Land of the free because of the Brave! 🇺🇸 Lifetime Member Supporting Member Club Contributor Dec 18, 2017 22,639 147,230 113 Missouri Ownership 1000-5 Nov 14, 2019 #3 T-bird said: On a 2019 700 2 seater what is the diameter of the small bar on top of the front bumper. Click to expand... The simplest way to figure it out is to use a piece of string and wrap around it and then measure that with a ruler or tape measure. Reactions: Backwoods
T T-bird New Member Apr 21, 2019 3 4 3 Poplar Grove, Arkansas Ownership 700-2 Nov 15, 2019 #4 Russ989 said: The simplest way to figure it out is to use a piece of string and wrap around it and then measure that with a ruler or tape measure. Click to expand... Ok thanks I’ll do that Reactions: Russ989
T T-bird New Member Apr 21, 2019 3 4 3 Poplar Grove, Arkansas Ownership 700-2 Nov 15, 2019 #5 Russ989 said: Not sure off the top of my head. Why do you need to know? Click to expand... Putting a light bar on it need to no what size clamp. Thanks Reactions: Russ989 and Backwoods
