Assuming you’ve checked alignment specs?
If you look at the pics I had posted, both front tires wore exactly the same, and the wear is nothing I have ever seen in a tire. The center and sides of the tire still have tread, but are nearly bald in between. Not an alignment or inflation wear sign.
I do not drive on concrete or hard pack much at all and the tire wear I got was perfectly fine.
The rigidity and overall adherence to finite parameters isn't there.
Soft rubber can be good. I do have to do some pavement driving, and a fair amount of hard pack. But the rears of my machine have nearly no wear, and I noticed significant front wear within 1000 miles.
I ordered some Tusk Terabites, so hopefully the radial truck type tire will hold up better, and for a majority of my rides, heavy traction isn't necessary. Mostly all forest service roads and jeep trails here.
