A
I am going to change both fluids, but before I do, is there any pitfalls to watch for? First-timer. Thanks!
Shouldn’t be too bad. When you are installing the Drain and fill plugs don’t over tighten. I have a P7hundo so I don’t know the intricacies. Just trying to give you some confidence.I am going to change both fluids, but before I do, is there any pitfalls to watch for? First-timer. Thanks!
Thanks Mudwing!Shouldn’t be too bad. When you are installing the Drain and fill plugs don’t over tighten. I have a P7hundo so I don’t know the intricacies. Just trying to give you some confidence.![]()
Thanks Mudwing!
So could you do mine while you have the toolz out?
Sure thang.So could you do mine while you have the toolz out?![]()
I’m glad you got it. I change my once a year because I mud deep. It’s good insurance.Just finished both front and rear differential. Pretty straight forward. Front was very difficult to refill. Need a flexible funnel with long enough reach. But I improvised with a piece of tubing connected to the spout of the oil. Looks good.
Thanks again!
I am embarassed to say when mine was done last. But then again, I dont use the machine to anywhere near its full potential.I’m glad you got it. I change my once a year because I mud deep. It’s good insurance.![]()
No need to be embarrassed around here. Maybe post a pic of that beast.I am embarassed to say when mine was done last. But then again, I dont use the machine to anywhere near its full potential.
You know, I was going to do that. As a photographer, I have pictures of just about everything. Would you believe I dont have a picture of this beast? I will get a picture this weekend and post it here. Also, I rotated the tires today. Still debating whether to flush the coolant. It looks clean in the reserve tank. Jury still out on it.No need to be embarrassed around here. Maybe post a pic of that beast.![]()
Here ya go Mudwing. Not too bad for a 2010 model.You know, I was going to do that. As a photographer, I have pictures of just about everything. Would you believe I dont have a picture of this beast? I will get a picture this weekend and post it here. Also, I rotated the tires today. Still debating whether to flush the coolant. It looks clean in the reserve tank. Jury still out on it.
You can buy a tester to check the coolant. Honda wants it done every two years. But I’d say if it tests good then run it.You know, I was going to do that. As a photographer, I have pictures of just about everything. Would you believe I dont have a picture of this beast? I will get a picture this weekend and post it here. Also, I rotated the tires today. Still debating whether to flush the coolant. It looks clean in the reserve tank. Jury still out on it.
Very clean.Here ya go Mudwing. Not too bad for a 2010 model.
View attachment 206563 View attachment 206564 View attachment 206565
