P700 Front seat cushion coming off
WagginTail
WagginTail
1,473
5,443
SC
Has anyone had the seat cushion come unglued from the plastic base? If so, what is a good adhesive to use? I tried some loctite spray adhesive and it worked for a few months but it's coming off again. Thanks
Backwoods
Backwoods
32,106
329,828
Douglasville ga
Yes mine did after about year they replaced it sight unseen with warranty I paid a 50 dollar deductible. The second one is holding up well.
Mudwing
Mudwing
36,959
306,563
The Mud holes
Mine is still intact. If I was having a problem I would bring it to an upholsterer’s shop. They may have a good glue or know better of what works. 😎
WagginTail
WagginTail
1,473
5,443
SC
Good idea. Thanks.
Reactions: Lady01 and Mudwing
Y
Youngen
Aledo
Mine came apart also. Gorilla glue worked for me. Clean surfaces well with rubbing alcohol and clamp it overnigh. Still holding after 2 years. Be sure to wear gloves when using glue as you can’t get it off!
WagginTail
WagginTail
1,473
5,443
SC
Great. I ended up using the gorilla glue max strength clear in the caulk gun. Seems like it will hold up well but haven't rode since I glued it.
P
pappyo
593
2,377
FYI : HAVE a Set of Honda P700 Front Seat & Haeadrest Covers CAMO - With automotive Seat Heaters Installed.
Only on about 100 miles before traded off P500 need 48in width. Excellent Condition.
Located Utica N.Y area.
Covers w/heaters have $260 in them take & 140 you pay shipping.
I do not use paypal.
Any interest use PM Please.
Lady01
Lady01
192
487
Midland Michigan
PermaGrip PG107 adhesive spray is the best on the market, you can get it here: Tractor Interior Upholstery LLC | Cab Kits | Tractor Headliners | Post Covers | Acoustical Foam
Permagrip PG107 Tractor Interior Upholstery
L
Lorraine
Richton, MS
Did this work? I have a 2018 Pioneer 1000/3 and my seat is coming unglued on the passenger side so I am looking for something to glue it back down with. Thanks!
Reactions: Lady01
WagginTail
WagginTail
1,473
5,443
SC
It worked for me but the boss didn't have good luck with it.
I pulled my cushion completely off and then pressure washed and cleaned the plastic base good with some brake cleaner. I removed most of the old glue around the edge also. Then I let it dry on the metal roof of my barn everyday for a week. Put the black side of the cushion up so the water can get out. I drilled the drain holes out bigger so water could get out easier also.
After it was good and dry I brought it in the house and glued it. I used 1 tube but I would have used 2 if I had it. Then I wrapped up the ends with a ratchet strap to pull the cushion down tight on the plastic base. I also set a bunch of ammo cans and boxes on the seat to help out.
