F
Yesterday, while out bombing around the area I had a decent smell of gas in the cab for a while. I was heading up a pretty steep trail from about 6,000ft to 9,000 ft, what little wind there was seemed to be mostly at my back on the way up, I have a front windshield and rear soft windscreen on, and I'm sharing the ride with the fuel tank on the passenger side, so perhaps this smell isn't unreasonable? (It wasn't strong, like a leak, but definitely noticeable.)
Once I turned around and headed back down the mountain, the gas smell disappeared and the cooler outside air was able to get into the cab. I attributed the gas smell to relatively stagnant air in the cab and also pressure changes in the tank due to the fairly rapid elevation changes on the way up.
But . . . once back to "normal" elevation, the fuel smell returned on flat ground, when I was headed in a roughly similar direction as earlier when going up the mountain.
I put 100 miles on the tank, mixed with mostly 2Hi but some 4Hi & 4Lo, not racing but not exactly slow, varied terrain between pavement, smooth gravel roads, fast trails, and slow rocky crawls. I put about 4 gallons in, so fuel mileage was within the 20-25MPG range everyone is reporting. Post ride inspection doesn't show any fuel leaks and the gas cap is/was tight; any leaks should show up well with all the dust coating everything.
I've not seen others report fuel smells while riding, but maybe it's so normal nobody is surprised or concerned? Is gas smell normal under certain conditions?
Thanks,
Mark
Thanks,
Mark
