Fuse box
Ryanp502
Ryanp502
34
122
New Haven Ky
I have a question about the duel battery hook up. I’ve watched every video I could find on YouTube.
Why do you need a fuse box and a negative and positive bus bar? The fuse box I was looking at has a place to hook up the positive to the fuse and it also has a build in ground block. See pictures. So do I need a negative and positive bus bars?? If I use a fuse box like this one?
2DA857E9 957E 493D A548 AD1326A6003B 7EF1B4CE 80FA 4954 B7AA F3012B948AE1
208,726
View attachment 333762 View attachment 333763
I didn't use bus bars, seems like overkill to me?
Ryanp502
Ryanp502
34
122
New Haven Ky
Agree.
Most installs I see with bus bars are not wired in a correct manor anyways.
And while those installs will "work", the power path invalidates primary propose of a dual battery.
Thank you sir. What gage wire do you recommend for hooking up my accessories and my stinger relay to my key on hook up?
Ryanp502
Ryanp502
34
122
New Haven Ky
Battery to stinger to fuse box?
#6 is most common.
Same size that comes with the winch and TrueAm isolator.
Got another question for you tonight. I ordered the duel battery kit. The 2022 don’t have the extra ground wire. Where would be the best place to ground it? The black ground wire looks to be about 9’’-12’’? I was thinking of just going to the ground on the main battery. Think that will work?
208,726
That's what I did, if I ever had a ground issue, I could trace it easily because everything would have a ground issue, I'm sure many will disagree, but it works for me?
Reactions: Ryanp502
66,869
To the main battery or create a proper frame ground.
