P500 Future rust issues….P520
stobiadas
stobiadas
115
463
K0E1X0
Hi all.
So I was doing some maintenance and disassembly for a future colour change on the plastic panels and while removing the plastic panels on the box I noticed a couple potential problem areas. Wonder if any of you guys plugged these holes. Mine were absolutely filled with mud and starting to rust at this point. I’ve had the machine for just a over a year. I think I will do a good spring cleaning and washing, fill in with some kind of corrosion resistance and see if I can plug these up. The trails in eastern Ontario Canada can get pretty messy and muddy at spring and fall time.
E1B417E8 33C6 41BD 84F0 C3103ACF7D26 624BF57F F37B 4A22 A195 B691A7625406 75FA326D 2432 4AA3 8380 78317D64367A 9549A717 0237 480B 9A38 3036FA9E1C3A
stobiadas
stobiadas
115
463
K0E1X0
The colour change will consist of wrapping plastics in vinyl wrap.
Buckshot07
Buckshot07
21,631
218,285
PA
Order some internal frame coating from Eastwood and treat ever frame tube you can. Comes with a tube with a fan nozzle on the end.
Buckshot07
Buckshot07
21,631
218,285
PA
You could try flex seal spray.
Your still going to have uncoated surface on the inside of your frame and bed tubing.
condensation from temperature changes will cause it to rust from the inside out just like a rocker panel on a car.
The long tube with the 360 degree spray nozzle in the Eastwood kit is the ticket.
I’ve used it for many things.
Buckaroo41
Buckaroo41
39
160
South of Heaven West of Hell
Would spraying the frame openings with white lithium grease, and applying the end cap kit be a viable option?
Reactions: Buggyman
stobiadas
stobiadas
115
463
K0E1X0
I found some plugs I can use. I think once I pressure wash it and let dry, I will paint rusty areas and spray fluid film before plugging.
