My shop was spray foamed, now I need to insulated garage doors. Most kits are 22" wide but the spaces between my channels is 24" wide. I am likely going to get foam board and cut it. My question is: I know EPS can take on a little water but it is flexible for insulation. Would you put in the EPS or the good one pink stuff? My openers are oversized so slightly concerned about adding more weight but not overly concerned.
Henry 1 1/2 in x 48 in. x 8 ft. R-5.78 EPS Rigid Foam Board Insulation 320817 - The Home Depot
Visit the Home Depot to buy R-Tech 1-1/2 in. x 4 ft. x 8 ft. Foam Insulation 310880
www.homedepot.com
Owens Corning FOAMULAR NGX F-150 1.5 in. x 4 ft. x 8 ft. SSE R-7.5 XPS Rigid Foam Board Insulation 88WDNGX - The Home Depot
Find the Foamular F-150 1-1/2 in. x 4 ft. x 8 ft. Insulation Board 270824, made for exterior wall assemblies tough, lightweight and offers exceptional insulating power at The Home Depot
www.homedepot.com
