Anyone have any experience with the 5 watt vs the 15 watt GMRS? Is it worth paying for the extra power? I have been using handheld radios with no problems but curious if there is much difference between the 5 and 15 watts before I purchase one.
NitroDriver... If you mount a base/mobile unit on your UTV with a good antenna, the base/mobile radio should show a useable improvement over a GMRS handheld with a fixed rubber Duck antenna. Even more so if you use the base/mobile radio on a vehicle with a good mag mount antenna. So the challenge is getting a good antenna on a UTV without a metal roof.
The full answer is rather technical, so feel free to ignore what follows.
Basically if you can get a 6dB gain, about one S unit, you should see a usable improvement in performance. You will lose some of the gain unless you run good cable such as LMR240 to the antenna.
Most handhelds have an antenna with about -3 dBi gain (minus). My mobile UTV antenna has 2.5 dBi gain. My base station antenna has a gain of 8.4 dBi. The advantage of a good antenna is the gain is there on both receive and transmit which is important if the rest of the family is on a handheld.
5 watts vs 15 watts is a gain of 4.8 dB. This helps only on transmit, not on receive. Still, the extra dB is useful if you are acting as net control.
Jeff
