Greetings from a new member who also needs advice.
67,698
I forgot to mention that even though the 10A START fuse is remains DEAD there are no starting problems.
Cant be.
You must be reading it wrong.
Fuses should be in this order
126fcd082b17252ed266c0630d0aa801
Look up under the hood and under the dash. There should be something plugged into this connector.
That's where the switch panel gets power with key-on.
There is also a 40a fuse on the switch panel harness. Check that.
E47f9060a091928baecb14c5cee7e4da
67,698
I have a switch harness here. I'll get it out and go over the peicses here in a bit.
67,698
Your looking for this blue plug under the hood. It should be hooked to a sub harness.
526ce176febd974531e7b7d62972b574
It connects to this sub harness.
F2f21aafb385c16b19e8f70d0f49c6da
Finally
This should be at the battery to provide power.
02206a7962c9910586c7762747e6f8be
And that all there is to the switch panel.
like2be
like2be
25
44
Socal
Yes exactly, I have all those harnesses and connections in place and exactly the way it sits as we speak. Again my fuse box lid says 10 A START and it's the third fuse from the right side and the 1000R starts no problem.
67,698
That all there is to it that I know of.
I guess start digging into it.
The little red wire and the large red wire coming from the battery side should have 12v key on power.
If the little red wire has key-on 12v, both large red wires should have 12v assuming the black is grounded correctly. If not relay could be bad.
Not sure about the start fuse then. I'll have to look the wire diagram over sometime. 360313e3623d6a3d2cfd3e9964318628
Backwoods
Backwoods
36,529
366,983
Douglasville ga
Welcome from west Georgia
like2be
like2be
25
44
Socal
Good afternoon Gents, I have just returned from the dealership where it was discovered that the only mistake I made with my light bar install was not to check and make sure there were no bent pins inside the p2 clip connecter on the main harness at the battery connection. THIS CASE IS CLOSED - LET THERE BE LIGHT!
Thanks for all the kind words and assistance. Please don't hesitate to call on me in the future if you need help.
Mudder
Mudder
NTC/TAP Transition Member
11,768
89,377
Welcome to the forum from GA.
Reactions: Mudwing
