Big thanks to sspeederr for the kit. I took my time and got it done without too much difficulty. I soldered, and heat shrunk the wire connections, which I highly recommend. I have one of those helping hand alligator clip thingys and that helps big time. Use flux! It helps. I thought I was home free, but then when went to put the pod on the steering column, I couldn't get the rubber boot through the hole. I ended up using a heat gun to soften it up, and finally got it.
i Used an engine turned pattern vinyl wrap on the switch plate. Thought it came out great. The secret to that is to sand the plastic to 220, then spray adhesion promoter on it. Then the vinyl sticks great.
I’ve got a bunch of other stuff to add, so it’s on to the next project! Pics-
