322,948
Ok one last ride with my daughter, she insisted. Cheers
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
This is mine. About to put it in the new machineView attachment 132084
Did you build that? Looks like that one is bolted on..
I get strengthening the other cross members, but just to confirm;
I see two wider cross members to the rear, and one more wimpy looking one toward the front below the coolant lines.. is that wimpy one there already? Is that the primary weak spot? Is the piece below going there to add additional support in that spot?
ToddACimer
ToddACimer
Pioneer 1005-2
3,773
15,981
Oshkosh, Wi
There's the wimpy lookin cross member at the bottom of the pic.. without any clamps on it. does your other piece bolt in right in front of that? Where the I see the bolts in the frame?
The weak spot at the missing crossmember is the exposed shift shaft for the sub transmission. At the back the 2 oil pan crossmembers are pretty flimsy and I punctured an oil pan.
You can see my crossmember bolted in right in front of the sub trans.
IMG 20190527 173933
Russ989
Russ989
22,645
147,289
Aiden asked earlier if you would bring your son when you came to Windrock? He would love to have a friend to ride with.
Depending on when we go, it’s definitely a possibility. I’m still in the dog house for leaving him behind on this last trip.
