Ford took advantage of everyone there for a bit in the ‘90s- early 2000’s...at least Dodge gave the Ford guts a quick fix with a proper engine swap.
Well.... Cummins .... gave Ford a helping hand for a decade, Dodge gave Cummins a way to get the engine to a Ford guys house.
Mopower58
Mopower58
Unburdened by what has been!
87,443
751,127
Crystal Springs,Ms.
Which kept you more busy, the s***ty engine or the s***ty way they crammed it in there so you couldn’t work on it?
Well in the late 80's it was glow plugs,injection pumps and wiring. Then they had a recall on all 460 powered ambulances for catching on fire. I went to a school to do those and did all the ones in Mississippi. Those took almost a year. Then comes along the 7.3 diesel, good lord at all those problems, early on it was injector orings,then it was injectors, IPR's leaking and filling with oil, ICP's causing engines to die, fuel heating elements shorting out and blowing the main fuse causing engines not to run. The way they crammed a 7.3 in an Econoline is a totally different scenario. Now they are trying to sell a pushrod V8 gas burner that they had for years (460) but discontinued because overhead cams and turbo's were supposedly the way to go. Now you have to pay 2,000.00 extra for a fuel injected pushrod gas burner (7.3)which they discontinued in 96 or 97. IMO they should just have modified the (7.5) along the way. The 6.0 and 6.4 diesels were another clusterf*** all together.
Fuel leaks were horrendous after the extra low sulfur was mandated by the government. Fuel filter o rings,fuel pump diaphragms were the worst. Also the fuel return line orings leaking and injector pump governors sticking causing dieing on 6.9 and 7.3 non powerstrokes. The low sulfur diesel is dry compared to the earlier version causing rubber to shrink and lubricated parts to stick. That is why diesel additives were popular.
Stuck in booth won’t allow you to switch out of park or even release the e-brake. Multiple codes popping up. Hate technology and hate European cars. Could you imagine going into the woods with your brand new $100k Range Rover With 39miles that you just lost 30k driving it off the lot and now you’re stranded looking for cell service to call a wrecker? Bhahahaha.
4E0205C3 5E45 4A3E 9B7D DD5372693117
Mopower58
Mopower58
87,443
751,127
Crystal Springs,Ms.
Can you just switch the key to the on position and bypass those safety features?
Nope. Doesn’t recognize the gearbox, cant do anything. Dial don’t let you shift. Tried reset and battery disconnect. Stuck like chuck especially being AWD, can’t even jack it up to get out. It’s costing us money. POS.
43,577
I'm surprised it made it into the booth. Those things are one of the biggest pieces of s***, but a good example of how a good advertising dept can convince those with more money than sense to buy a turd.
