Coeus
Coeus
Major General
58,561
586,750
Signal Mountain, TN
  2. Talon R4 LV
Happy Hump Day y’all!
71FC218F FEAD 4EFB AC63 AD2924EC3F84
RingMaster
RingMaster
176
710
Little Rock, Arkansas
Cheers fellows! Here's what $500+ worth of parts and an extended ride in the snow get you when your bearings go out. I just finished doing some wrenching tonight. Thanks to @Roofrack and Daniel for their help. The Pioneer is ready for a ride this weekend!
20210303 164414
41,751
Cheers fellows! Here's what $500+ worth of parts and an extended ride in the snow get you when your bearings go out. I just finished doing some wrenching tonight. Thanks to @Roofrack and Daniel for their help. The Pioneer is ready for a ride this weekend! View attachment 258591
How many miles? You don't see bad bearings all that often on hondas.
208,011
DANG!
RingMaster
RingMaster
176
710
Th
How many miles? You don't see bad bearing all that often on hondas.
The sad part of it is that these are the second set of bearings. My first set lasted 7000 miles. I just installed these bearings about 2000 miles ago. I have no idea what caused these to go out much faster than the original ones. The other side was going out too. I replaced them tonight as well. Crossing my fingers that these last longer.
208,011
Th
Loose nut behind the wheel?
41,751
Th
Did you torque the nut or ugga dugga it? Too much torque puts side load on them...at least that's what the instructions I read afterwards say...
41,751
How'd this look on the old pion ear?
RingMaster
RingMaster
176
710
My torque wrench only goes up to 80 ft. Lbs so I had to use the gorilla method. And with a 3 foot breaker bar I'm sure I had a lot of ft. Lbs on it. That's why I'm going to borrow a friend's torque wrench tomorrow. But I thought I didn't have enough torque, maybe this side load thing was the problem? Thanks DG.
41,751
Sounds like a plan.
319,757
Oooh! I could use a box of those for different things I own.
66,323
Th
Its supposed to help a lot to grease the new bearings right away. I did. And still feels great after 1000 miles.
