P1000 Hard Front Doors - REPLACEMENT PARTS - Pioneer 1000
66,816
Replacement Parts List: Hard Front Doors
Part Number 0SU95-HL4-105 (2018-20)
and
Part Number 0SU95-HL4-104 (2016-18)
Agearibarimariazoom3path2Fimage2FHOM2F57eb1eef 36c1 4586 8138 0be697fe7cc42FMedium
See attached.
Other parts here --> P1000 - Accessory Replacement Parts Listing - Hard Parts!
Not listed = Not available.
6 - Part# 0SU95-HL4-104R16 UPPER, L. HINGE $67.95 $59.73
7 - Part# 0SU95-HL4-104R14 LOW LH HINGE $57.95 $51.67
8 - Part# 0SU95-HL4-104R13 UPPER LH HINGE $67.95 $59.73
9 - Part# 0SU95-HL4-104R12 LOW RH HINGE $57.95 $51.67
10 - Part# 0SU95-HL4-10R7 6X20MM BHCS $12.95 $11.60
11 - Part# 0SU95-HL4-10R9 8X20MM BHCS $12.95 $11.53
12 - Part# 0SU95-HL4-10R10 10X130MM SHCS $12.95 $11.26
13 - Part# 0SU95-HL4-10R3 6MM FLAT WASHER $12.95 $11.67
14 - Part# 0SU95-HL4-10R4 8MM FENDER WASHER $14.50 $13.33
16 - Part# 0SR85-HL4-101R4 6MM NYLOCK NUT $12.75 $11.74
17 - Part# 0SU95-HL4-10R1 8MM SER FLG NUT $12.95 $11.47
18 - Part# 0SU95-HL4-10R2 10MM NYLOCK FLG NUT $11.50 $10.47
22 - Part# 0SU95-HL4-101R2 R STRIKER BRKT $24.75 $23.00
23 - Part# 0SU95-HL4-101R1 L STRIKER BRKT $24.75 $23.00
24 - Part# 0SU95-HL4-101R3 STRIKER PIN $17.75 $16.00
25 - Part# 0SU95-HL4-101R5 L HINGE COVER $25.95 $24.00
26 - Part# 0SU95-HL4-101R5 L HINGE COVER $25.95 $24.00
27 - Part# 0SU95-HL4-101R6 R HINGE COVER $25.95 $24.00
28 - Part# 0SU95-HL4-101R6 R HINGE COVER $25.95 $24.00
29 - Part# 0SU95-HL4-10R20 TRIM CLIP, DOOR $14.50 $13.19
33 - Part# 0SU95-HL4-104R11 DOOR LIMIT STRAPS $59.95 $51.67
34 - Part# 0SU95-HL4-104R18 RH DOOR GLASS $149.95 $126.77
35 - Part# 0SU95-HL4-104R17 LH DOOR GLASS $149.95 $126.77
36 - Part# 0SU95-HL4-104R19 A-PILLAR GLASS $59.95 $54.67
37 - Part# 0SU95-HL4-104R20 HL4 WINDOW CHNL $40.95 $38.33
39 - Part# 0SU95-HL4-104R6 WINDOW CRANK ARM $32.95 $30.67
40 - Part# 0SU95-HL4-104R10 B-PILLAR HD DR SET $249.00 $220.31
  • Hard Front Doors.pdf
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
Ran across a few HARD TO FIND replacement parts.
Is there one for soft upper
Reactions: Hondasxs
Jsb1234
14
12
Alabama
I just bought a set of hard doors from a buddy that had his pioneer stolen. He had them off of the sxs for summer time and all of the hardware went with the sxs. Is there anywhere I can order all of the hardware together? I paid $600 for the doors thought it was a good deal but now I’m not sure
Reactions: Robobrainiac
Rs479
Pa
  1. Looking to buy
Open pdf file in this thread and then google part numbers you need
Jsb1234
14
12
Alabama
Thanks I found most of it, any idea why nuts and bolts are priced so high? I’ve seen two websites selling 8mm flat washer for 13.99 unbelievable
Jsb1234
14
12
Alabama
I’ve got all the parts except for the inner and putter strike clamps. I’ve searched for hours and can’t find a part number anywhere. Anybody know what the part numbers may be for those?
