P700m4 Hard roof install question
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
So I got my hard roof today and put it on. The rear seems to line up right, however the front does not seem to symmetrical. The clamps are the same distance from the outer roll cage. The drivers side the roof covers the frame bolts that face outward. The passenger side does not come out or down enough to cover them. Has anyone run into an alignment issue?
Reactions: Corona1
tjoreo
tjoreo
1,025
1,975
Southern Idaho
I don't remember having that problem with mine. I'll take a look tomorrow and let you know. The bigger question is, does it fit in the garage?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
It fits in the shed. I got a 7ft garage door on it. I do have to chain the door all the way up though. If I don't the door hangs down too much and wouldn't fit
SundayRdr
SundayRdr
575
1,179
McMinville Tn
You can take the rear & midsection clamps off remove the brackets and drill 2 new holes in each of the roof brackets for the clamps. You will fit in an 80" opening with commander shocks and 28.5 tires.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
got any pictures of what you are talking about? how does this affect the roof as far as flex goes?
allgm1
allgm1
1,049
1,484
New Hampshire
I don't think there is any part of the hard roof that it symmetrical. Mines the same way,looking at it from the front you can really see it is crooked. I just center mine up left to right and clamp it down when I'm putting it back on.
Corona1
Corona1
319
878
The Land of Cheese
Had similar issues when installing mine. Loosened all clamps, centered visually and clamped back down. Clamps no longer are same distance from ROPS, but unless you put a tape to it no ones the wiser.
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Once installed and more clearance is needed remove the plastic clamps from the L brackets and drill 2 new holes in each bracket relocating the clamp. For the rear brackets simply unbolt them nd flip them over and reinstall the bolts. The midsection of the roof will now sit ontop of the upper cross bar above the passenger compartment.
20170117 163802 1484692876785424206007 14846930139951948157134
allgm1
allgm1
1,049
1,484
New Hampshire
@SundayRdr I like that, must have to trim the roof back when using honda soft doors?
allgm1
allgm1
1,049
1,484
New Hampshire
I don't know about trimming for the fabric doors, I'm a tight ass and can't break down and buy them.
they make sunday rides a lot more fun in the cold weather, I'd love to lower my roof an inch or two so i can get in the garage without rubbing....going to look it this a little deeper real soon.
