N
2019 talon x. 5000 miles was getting hard to move shift lever between gears. Dealer says its the shift plate under the shift gate. It's rusted and binding up. Anyone experience this? Nothing on the forums I could find.
Did you have it into the dealer or did you just call them and ask?Dealer says its the shift plate under the shift gate. It's rusted and binding up.
It's at the dealer after they did their s*** what's the word... analysis. Inspection. Some fancy wird.Did you have it into the dealer or did you just call them and ask?
Since you said it’s at the dealer and you just looked it up in the manual why don’t you pick it up and take the shifter apart try to clean it upFrom the service manual why can't they just clean it up and lube it. Just a pivot point or am I missing aomething.
No I believe number 4 is binding up is what they said.
Maybe #4?
I had edited my post the same time you replied, lol.No I believe number 4 is binding up is what they said.
If you disconnect the cable from that plate, if it moves freely, your problem is elsewhere.No I believe number 4 is binding up is what they said.
They called yesterday while I was on the road and not home. The parts guy wasn't well versed. I gave the go ahead to just get it done. I'm leaving on a trip with it next week. After I went into the dealer today I actually realized what they were talking about and would if just done that. I was.actually thinking shift fork or something similar was the issue or shift cable.Since you said it’s at the dealer and you just looked it up in the manual why don’t you pick it up and take the shifter apart try to clean it up
