Or have someone sit on the tailgate.Roughly that yes. Can vary a touch on tires and shock preload.
I say get it then if its too high to get in the garage let some air out of the tires
My 2018 is sitting on 28" tires. Height to top of honda roof is 80"2024 1000-5 Deluxe, does anyone know how much height the Honda hard top adds? I’ve got 3 1/2” left above my bare back bar when pulling in my garage, the door is as high as I can get it. I have just about 80” total clearance.
Ugh…..My 2018 is sitting on 28" tires. Height to top of honda roof is 80"
With the OEM windshield and hard mid panel the roof sits about 2-1/4" above the roll cage at the middle bar You may be able to pull that down if you do not have the hard mid panel2024 1000-5 Deluxe, does anyone know how much height the Honda hard top adds? I’ve got 3 1/2” left above my bare back bar when pulling in my garage, the door is as high as I can get it. I have just about 80” total clearance.
I'll try to measure the actual distance from top of roll bar to top of roof this eveningUgh…..
You need a bigger garage!Ugh…..
Does that include the raised portions of the roof?OEM roof and stock tires and I’m right at 78.5”.
When I thought I wanted an enclosed trailer I was looking for 80” tall opening minimum, anticipating different tires.
Just realized I’ve got 27” tires, just gained 1/2” 🤣😂🤣My 2018 is sitting on 28" tires. Height to top of honda roof is 80"
No I measured at the bottom of the drip edge. Does that make a difference?Does that include the raised portions of the roof?
Sorry, I guess my question did sound stupid, if measured just above back bar I don’t know if anything is higher on the roof. I’m going to blame Pabst Blue Ribbon on this one.No I measured at the bottom of the drip edge. Does that make a difference?
Id be astatic to gain 1/2”😏🥳just gained 1/2”
you could always do a Rops ChopI’ve got a $250 rebate that’s on now from the purchase that’s good for Honda accessories, the roof at the moment is the only thing Honda that I’m looking at. That’s the reason I’m being so inquisitive 🧐. I’ve been told by my dealer that if it won’t fit I can return it if not scratched now.
