P1000 has anyone had valves adjusted
JOHNDEEREMAN
22
17
NEVADA
i went up in the mountains yesterday coming back down it started back fireing in muffler i was a block away from home motor quit running service engine light came on turned key off and it started back up if i tried to run it over 1500 rpm it would die taking it to dealer when they open ruined the rest of holladay ride someone said cataltic convert mit be plugged
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
How many miles do you have on your pioneer 1000?
JOHNDEEREMAN
22
17
NEVADA
i have 3800 plus miles 280 hrs its run good so far no problems until this its going to worry me now because i go on some 100 plus mile rides im retired and ride alot dont like to walk very far
Reactions: CumminsPusher
hondabob
1,259
4,988
Prescott Valley, AZ
The dealer can check the failure code to see which sensor failed. Turning the key off then restarting resets it and the failure may turn the check engine on again. It should be an easy fix. You may want to check the engine ground wire. Follow forward from the engine to the frame under the drivers seat. Also check the battery terminals too.
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Here are the grounds. The spark aerator is easy to check just take the 3 bolts of the exhaust tip and it comes out
JOHNDEEREMAN
22
17
NEVADA
thanks ill check ground and spark aerater i wouldnt think it would be plugged just that i run down some roads 40-45 mph you would think
that would keep it clean i also run 89 octane all the time a guy that was ride with me said the back firing can cause cathltic converter to melt
it was getting pretty loud
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
With that many miles you need to check the air cleaner it should be replaced at 3600 . The spark arrester needs to be cleaned every 600 miles and if you never adjusted the valves it might need to be done.
