P1000 hdb444's p1k5 build
hdb444
hdb444
9
21
sc
just wanted to show a few of the things I did after gathering a bunch of yalls ideas and putting my own interpretation on them. first was adding second battery an isolator and the bussman fuse box.
20736 7818e3ffb46bd7fd23d2b45566cc716120737 8e0ac9ccd8271494579ddf724a688853
next was the 50" lightbar and two cube lights for the rear
20740 a0caaebda89f64df7f90a14760a789db20741 5aa6c2a56dd91e0f04ea1fa26d1017c7
then switch panel with room for future expansion for radio among other things
20742 b1a16dfb7b1f356aef87c90dc3ac8afe
and heres the insulation attached under the seat. its also under the seat back and between the back and the bottom. also the 4" bilge fan.
20743 846af9cdde4f9b178f5a042d216ece72
thanks for all the ideas. funds are depleted now, but more to come eventually!
IMG 0934 IMG 0935 IMG 0929 IMG 0931 IMG 0936 IMG 0933
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Nice work! Fund depletion is a common ailment around here. What else you got planned?
Reactions: pct and sharp
hdb444
hdb444
9
21
sc
thanks it was a lot of work, probably most of it staring at it trying to figure out how I wanted to do it and changing my mind a lot along the way. next thing that probably get done quickest is radio and sound bar. then later on down the road full skids when I can stomach the price (mainly the wife)! also a snorkel at some point. then who knows.
Reactions: pct
sharp
sharp
3,757
14,955
Tennessee
You have a great start. Let it marinate for a while then you will know your next move.
Reactions: pct
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Welcome aboard.. got it looking good. Once you start there is no end, always looking for something else to do to it.
taylorman
167
97
Lafayette La
Would you mind showing a close up of how the light bar is mounted?
hdb444
hdb444
9
21
sc
just used a piece small piece of angle iron drilled and tapped one of the roll cage bolts on each side. then I had to drill new holes in the supplied brackets that came with the lightbar. its real sturdy the way the supplied brackets rest against the roll cage. IMG 0939 IMG 0940
amc019
amc019
480
592
Little Rock, Ar
Interesting method with drilling and tapping the actual bolts! I have a 52" curved I've been meaning to get mounted in the same place for awhile now.
Reactions: pct and joeymt33
View attachment 21210View attachment 21211
View attachment 21212View attachment 21213
View attachment 21202 View attachment 21203 View attachment 21206 View attachment 21207 View attachment 21208 View attachment 21209
Funds are ALWAYS depleted on these things! That's the crappy part. But it's always fun enjoying them. Nice job everything looks tight. Welcome to the club!
hdb444
hdb444
9
21
sc
thanks got a lot of ideas from folks like yourself. maybe someday I can take the plunge and chop the top like yours!
Really though nice job. It's hard to keep everything clean on install. There's too many ideas on here and just not enough time or money.
Sent from iPhone
pct
pct
Lost in the hills
790
1,023
Letart WV
Welcome you will love it and yes what they said to many ideas and not enough money HaHa Looks good keep us posted on your updates
Mattyb39
Cranberry Township, PA
finally got my radio installed used a boss marine radio with polk speakers. mounted speakers in pvc end caps like another member on here did. really liked the way it turned out.View attachment 22951 View attachment 22952 View attachment 22953
Can you give me any more details on that speaker setup? Like what brand and size speaker? How you mounted the speaker inside the cap and did you need to vent the cap? I bought schedule 40 6" caps but I'm not sure how to do the rest so I haven't even started on that project yet.
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
You'll need a length of 6" Pvc pipe as well, cut off a 2 or 3 inch length and cement it inside the cap flush with the edge so the screws holding the speaker have something to bite into. No venting needed, just drill a small hole in the bottom to feed the wire through.
Reactions: Mattyb39
Similar threads
Replies
Views
523
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
