P500 He’s dead Jim
someguy1313
someguy1313
242
523
SouthEast
i know it's old, but also curious about the install
Mudder
Mudder
NTC/TAP Transition Member
11,882
90,580
First off, welcome to the forum. If asking about an option for winch wiring with a protective breaker, I’ll give it a shot. This breaker is a also a benefit by being switched .
Link to a good thread. P500 - Rusty's Juicebox #nohomo
Check your winch max draw and ensure the breaker amp rating is sufficient, might be in the 200-300 amp range, and be sure to match the wire gauge for the amp rating.
I mounted the waterproof switched breaker on 6 gauge wire just off the battery behind the passenger seat frame, then removed the skid plate and ran it to the hood, also wrapped inside split loom wire jacket for extra protection again chafing shorts.
This drawing from @Rustneversleeps shows he also added a separate relay circuit and fuse block to provide more accessory power and terminals for more amp capacity than provided by the 15 amp total OEM sub-harness, Not necessary if just hooking up the winch.
Hope this helps.
75417182 384D 4647 9191 3E7AB25FB961
0DD06B15 D9BF 44D5 8E01 727ADC8ED604
Reactions: trigger
