Hello, my head/tail lights stopped working. I pulled and replaced fuses--still inoperable. I did notice water in the tail light. Could this cause the headlights to quit working too? If not, any other thoughts?
You need to check power at the light with a meeter to see if you have voltage going there then work your way back then find out where the brake in the wiring is or if thats good, the source like the switch. But check the voltage first and work your way back . As for water in the light being the cause? Sure, IF the water got to the socket and you would see corrosion but most likely would have blown the fuses that you said were good.Hello, my head/tail lights stopped working. I pulled and replaced fuses--still inoperable. I did notice water in the tail light. Could this cause the headlights to quit working too? If not, any other thoughts?
