JKW heat shield will greatly reduce the engine heat coming from under the seat. My heat shield has punched holes for the seat post which makes for easy alignment during installation. Seat belt slots are cut unlike others for sale. To install just remove the push pins from the plastic trim between the cushion and seat back. Place the heat shield over seat post and tuck the back under the plastic trim. Use a screw driver to punch holes for the push pins, reinsert the pins and you’re done.
JKW cup holder fits the Yeti Rambler 20oz and 30oz mugs as well as the Yeti Koozie. Powder coated steel base with PVC cup holders. To install use the steel base as a template to mark the holes, drill 7/32” holes thru the square tubing under the seat and bolt in place with the supplied alloy bolts.
Easy ordering from my website shopping cart and PayPal.
www.jkwoffroad.com
www.jkwoffroad.com
