P1000 heat through shift lever holes..anyone have fix 1000-5
coues52
29
45
I have a 2016 Honda Pioneer 1000-5..trying to reduce the heat issues in the cab.. fixed inside engine compartment 8" fan & DEI heat shield kit.. now working on the inside..have factory Honda Glass windshield, Honda full hard doors & rear cab kit....anyone have any thoughts..thank you Danny B
K
kevin1
24
23
Alabama
Montana on this board makes the shift hole covers I am actually waiting on a response from him now I need one and have two buddies needing them also
Only way to get rid of the heat inside is to remove as much of the cab enclosure stuff as you can for the hotter months it works best with no windshield at all
Reactions: clifforeilly
coues52
29
45
Kevin1,Thank you for the fast reply.. sounds great on Montana offering the shifters holes covers..I will order some for sure..agree ..it may come to that...removing cab enclose stuff..Danny B
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
There is a air deflector that goes behind the radiator fan that helps a lot to keep cooling fan from pushing air in the shifter holes when it's running.
coues52
29
45
Great..I contacted the Local Honda dealer and order both parts..luckily my frame was pre drilled.. thank you GPR1500SC & Lee...Danny B
Reactions: lee
Skin0375
Skin0375
42
59
West Virginia
Go to your local AutoZone, purchase an aftermarket shifter boot, slit the sides slightly, ease over your shifter, ease the sides under the crease in your dash, boom...looks factory and no more air thru the shifter, less than $20
BBLASER
159
277
Phoenix
Picture?
Reactions: Plumber32
russknight
russknight
1,910
7,511
Perry Florida
I inverted a boot under the dash. I countersunk tapered head stainless screws and used flat washers with lock nuts on the back side plus used adhesive to help seal it. It works perfect.
Shifter Shifter2
Madmax88
Green Bay Wi
Russknight What boot did you use? If you could share a link that would be great. Thanks
russknight
russknight
1,910
7,511
Perry Florida
Here it is. It's not a perfect fit, and has to be slightly modded, but it worked out great.
https://amazon.com/gp/product/B06XYP2Y28/?tag=sxsweb24-20
