I work on a big ranch and we have a lot of hondas. 1000's and 700's. In the winter I've taken to helping fix issues with them as we have been keeping our local dealer in business and we're trying to cut a little cost. I've taken apart a 1000 subtransmission and replaced the reverse gear (with a service manual) and swapped stators on a 700 so I'm getting braver about diving in and trying to repair some of this stuff. Certainly not a mechanic but not afraid to try.
Picked up a 2016 700 from another unit on the ranch the other day to work on. It has just shy of 17k miles. (They're used daily around here). Apparently it had some starting issues last summer so the starter and ecm were replaced. It ran well for a short time then went back to same problem and also wouldnt shift so it was parked. The first thing I did when I got it here was check the oil. Of course it was low so I filled to correct level and took it for a spin and voila, it shifted like it was supposed to. I drove it for about a half hour and it misfired and just died. Like turning off the key. I hit the starter and it fired right up but when i got to about half throttle it began missing and backfiring all the way back to shop. Bout a half mile. Sounded like a rev limiter was working too.
Today I took all the plastic off, pressure washed it and adjusted the valves. Exhaust were fine, intakes were loose so I tightended them to spec. I took it for about an hour ride and I cannot get it to duplicate what it did the other day. Took it up some steep hills and it seemed to have plenty of power. It starts every time, but it's loud. The exhaust is tight. I can hear a pretty apparent tick or slap that sounds like it's coming from deeper in the motor than the valves. Idles fine, revs up fine. I have a 700 service manual on the way and am preparing to pull the cam. Thought I'd ask here to see if I'm on the right track or if I'm looking in the wrong area. Thanks
