Hello everybody,
So a couple of weeks ago we trail ride for about an hour and my pioneer 700 did fine. Got home washed it with water hose. I never use pressure washer. Raised the bed and washed up under it. Let it set in the sun to dry for a couple of hours and when I got in it to put it under the shed, I noticed the fuel hand blinking. Killed it and crunk it back up and same thing. Unhooked the battery to see if it reset, checked fuses, checked where the connector plugs in on the fuel tank.All looked good. So I though no big deal, I’ll just check gas level with a rod. So I been checking it with a stainless tug welding rod. So ever since then it has also died at least 8 times sporadically. Cranks right back up. Any ideas on this.
Thanks for the help
Thanks for the help
