The guy I bought my 2017 P5 from put a 53% reduction, 12 oclock labs speedo healer and was running 33's. I changed back to stock gears and removed the 12 labs speed healer and am running 30"s. I have adjusted the clutch until Im blue in the face. I was finally able to run thru the gears in manual mode: N, R, 1, 2, 3, 4, & 5 but you either have to have the motor revved with high rpms between gears and slightly take your foot off gas when hitting the paddle shiftier between gears? I tried auto and it will not come out of 1st and the display goes from "D" to "-" (dash) . I have to turn it off then back on to get back to manual mode and even used the tool to physically change the gears. It was pretty tough to move. When I took off speedo healer and re-plugged sensor in, I used a little dielectric grease...could this have an effect? Reckon I put the auto shift together wrong? The fact that I can run through all the gears is a plus in my mind but hope I didn't mess anything up internally. I need it ALL to work correctly in manual AND auto. I have been trying to adjust the tension on the clutch with the adjustment screw. I think I have the clutch adjustment correct. I have taken battery loose, and re plugged the speedo repair and re programmed it still didn't work. Got any ideas? Kinda desperate ! ANY and ALL help will be appreciated!
