My tail lights went out , i checked all fuses, all good.. any other ideas ?
Same for me.. if you figure it out let me know and ill do the same2021 with 350 miles doing same thing got brake lights just no running lights got power to back for running light bench tested light and brake comes on but no running lights
BROMAN!!!! C’mon man! Your from Michigan! One post no pics Of your machine!2021 with 350 miles doing same thing got brake lights just no running lights got power to back for running light bench tested light and brake comes on but no running lights
When u turn your parking lights on, have one of your taillights out and check for 12 vdc at the plug at the light. if you have 12vdc there, then its your light. if you dont, you have to trace that wire from that point back to see where the “brake” is. This is assuming you checked your fuses and there good?Same for me.. if you figure it out let me know and ill do the same
Did you tell this joker that you have measured DC power at the lights and they still don't work? And that other people have reported the same problem?So just picked my machine up from dealer after first service and to fix my taillight issue and was told Honda will not cover my lights because there is a light bar installed and since both lights stopped working I must have did it wrong anyone else dealing with this?
I have 12v at light that means no blown fuss or broken wires, the light bar is not wired to factory battery and also has a fuse on the power to light bar that has never blown and works correctlyThe Honda dealer is not very helpful to a customer but they are also not being unreasonable. It's reasonable to assume the addition of the accessory light bar is related to the simultaneous failure of taillamps. Reading between the lines you were probably told their labor to troubleshoot and repair and the cost of an unknown part would be your responsibility and you declined.
It's not a big deal. Troubleshooting 12 volt DC (direct current) electricity is very simple. All you need is a basic 12volt test lamp or multimeter. A test lamp is better if you're not knowledgeable of DC electricity
Start the machine and let it idle and turn on the lights. Start at the taillamps and measure voltage at the back of one of the lamps. Then work backward toward the source of 12 volt power moving to the back of the switch, the ignition switch, then continue through fuses or breakers ultimately back to the alternator and battery. When you find 12 volt power you have moved past the blown fuse, disconnected or broken wire, or ???. Somewhere in that chain you'll find a problem.
The simplest is a fuse. When work has been done it's reasonable to look for a mistake such as a forgotten wire, broken wire, or other human cause.
Yes I did waiting for dealer to call back honda customer service said it would void warranty only if dealer told them the accessories caused the issue. Sounds like there passing the blame back and fDid you tell this joker that you have measured DC power at the lights and they still don't work? And that other people have reported the same problem?
Are you talking about running lights or stop lights?I have 12v at light that means no blown fuss or broken wires, the light bar is not wired to factory battery and also has a fuse on the power to light bar that has never blown and works correctly
Have good ground use the ground in the plug as meter ground and it shares ground with break lights witch work fine, and there are no bulbs in the 2021 it's LED'sAre you talking about running lights or stop lights?
Are you saying 12v volts is present at the lamp but it doesn't light? If hat's the case the ground (return) wire is broken or disconnected.
The body of our Pioneers is plastic so a return wire is required.
Has anyone disassembled the lamp(s) to ensure the correct bulb is installed, the bulb is good, and the bulb is correctly seated in the lamp socket?
