HBarlow
Can you remove and test the LED lamps? If power and ground are both present and connected properly the lamp or lamps are suspect.
I have a 21 that had a tail light die, dealer replaced wout issueHaven't read all the above. Hard to follow along some of it.
Anyways. Just wanted to say there have been several 2021 machines with a DOA tail light units.
Well folks new lights came in worked fine put around 6 hrs or so on them and today my buddy riding behind me says driver side not working 45 mins later when loading up after weekend both out there dead again so let's see what happens this time
Do you have a duel battery setup?My machine is currently in for its second pair of replacement tailights (burnt out twice). 2021 1000-5 with 200 miles and very little night use. Gauge cluster backlight has also now failed . Honda has directed the dealer to replace the regulator as well. Dash mounted voltmeter hasn’t indicated any excessive voltage however….
