P1000 High Clearance A-arms
SuperDutyJohn
SuperDutyJohn
254
438
Vero Beach, FL
Only if you drill a hole in the steel bushings to allow the grease to reach the bolt
I thought it went around and went back in? At least that's what I hoped for, I do see grease at least coming out the sides.
P1000m5 - Rock Donkey
My build thread has videos and pictures. The grease can't get to the bolts, my bolts were worn, several other members have had much more wear. They wear then wallow out the mounting tabs and you can see the amount of movement at the wheel in the videos with just a small amount of wear.
208,731
That they do.. if you have plans of running a 30” tire then go for it... but don’t do it thinking you’re gaining ground clearance.
I beg your pardon? You will gain clearance from the larger tires and replacing the sags out stock shocks;)
Reactions: JTW
Fl-Cracker
Fl-Cracker
42
86
Fl
67954CB1 D416 4A21 96D2 CE433F62743C
Really gotta watch out for those 5 gallon buckets out on the trail:cool:
Lmao. Just think of that Bucket as stump under water you don’t see
Fl-Cracker
Fl-Cracker
42
86
Fl
