high lifter 2.5in signature series kit
T
TimE
23
36
Oklahoma
Hello. So I installed a 2.5in high lifter kit on my 1000-5 LE. I put 1.5in spacers on to alleviate rub. I noticed the angle in the rear was pretty steep but I thought it was supposed to work with stock a-arms and axles. Went on a ride and noticed a popping in the rear on turning in 2 wheel lock. Tested in the yard and major popping on sharp turns.. Long story short.....took off the lift off popping went away. Dealer said they have problems with about any kind of bracket lift over 1.5in. I like the lift so is there anything I can do to make it work without spending tons of money? Thanks!
Reactions: Isaiah and TxDoc
272,156
Well being as the LE axles are all different from every other P1K model (LE has bigger differentials - read axles are shorter) you can't just slap on Rhino Axles, etc. No one I know of makes aftermarket axles for the LE version.
You need a greater articulating CV on both ends. You really are better off not using any lift with the LE. Run 28" tires on it no spacers and call it a day. I ride in some pretty rough trails with 5k miles on my LE. Haven't been in any situation that lift would have made a difference. It's all psychological ( bigger is better) except when it isn't. In this case it isn't. Selling the lift to a non LE owner would be your best route economically & mechanically from a reliability standpoint.
T
TimE
23
36
Oklahoma
Thanks for the reply. I guess I didn't realize how much difference there was between the models. I would like a little lift however... Im not into big lifts, or portals etc. but when I'm loaded down with 4 adults and an ice chest it is very squatted. Looks kinda like a low rider 😄 I get tired of dragging on rocks that I shouldn't have to be. The one ride with the lift was awesome. That extra 2.5, 3 in made a huge difference. But I guess if there is nothing out for it I will have to deal with it. Thanks for letting me know.
272,156
If you don't already have full UHMW skids and A-Arm guards - replace the trash aluminum ones that come on LE. That is the single best thing you can do if hitting objects in trail.
Think of the aluminum as a big cheese grater attached to underbelly grabbing and dragging on everything it touches vs. a UHMW acting like a teflon cutting board that glides over mud and rocks. I will post photos of my badly damaged aluminum and difference FUTV ULTIMATE UHMW skids make coverage wise.
Coverage difference OEM plastic & aluminum vs FUTV UHMW
20190702 155252
LE Aluminum 2500 miles beat up, 5 bolts sheared off by rocks.
20190813 110141
20190813 110148
20190813 110152
20190813 110207
20190813 110159
Note exposed side sections NOT covered by aluminum above and below photos and damaged outer rails smashed out of round by rocks.
20190813 110203
Bent skids should lay perfectly flat off machine
20190813 112650
Full UHMW coverage installed
20190702 193232
272,156
Here is a full thread on the topic with more information and details.
Reactions: TripleB
Robobrainiac
Robobrainiac
2,551
8,962
Just out of curiosity did you sell your lift?
T
TimE
23
36
Oklahoma
Sorry for late reply. I still have it. Plan on keeping just in case...
Robobrainiac
Robobrainiac
2,551
8,962
That's OK. I was just curious if you may want to sell it.
