P
Thanks in advance to all that can help. Lost the high rpm on a 2011 700muv. runs and starts perfect, have to let off throttle to shift because it lays down on the last half of the throttle. Top speed was 41, now its 26. can get a couple more mph if hold at half throttle because it will fall flat if you push throttle down more. Have no codes and checked the spark arrester and air filter. oil level is correct and the trans seems to be normal. it does't act like valve float, maybe timing advance? Anybody heard of this-and/or what the problem was?? Thanks again, GARY
